Gyeon Cure I recently coated a 2014 Porsche Boxster S with Gyeon Prime. After curing, I performed a final wipe down using Gyeon Cure. Cure really slicked up the surface. It was very easy to use, left no residual smearing, was pleasant smelling and left the surface very, very slick. Gyeon Cure is a great final wipe down or booster for a coated vehicle.
Is cure like a reload or permanon? Is it meant to be additional protection, or just stick around until Mhos cures? I know from following your posts that is adds slickness which I love, but: 1. How long does it last? 2. Does it stick to Mhos 3. Why not use can coat or booster as I think they are longer lasting and I have used booster over Gyeon coatings successfully per Gyeon Jeff. Thanks and nice work.
From DD's site: Q2M Cure HYDROPHOBIC SPRAY SEALANT Q2 M CURE is a fantastic maintenance product for use after any of the GYEON coatings, it adds extra hydrophobicity, makes the surface feel slicker and has fantastic anti-static properties. As Q 2 M CURE is based on SIO 2 , its regular use will have a major influence on the base coating's durability by extending its performance EASY TO USE GLOSS Q2 MCURE can be used after washing when the car is wet or dry, just 1 or 2 sprays per panel refreshes the coating underneath and adds extra gloss and protection. This will protect against water spots after the original coating is first applied, and provide a constant boost to the protection if used after regular car washing. As a proper ‘Quartz Quick-Detailer’ this spray will add great shine and provide that ‘just coated’ appearance to paints lasting up to 6 weeks between applications. I don't know how long it will last...I will go out on a limb and say depending on how the vehicle is used, up to a month or so. Perhaps GYEON or Phil can chime in here. It does stick to MOHS. And for the reason for using it, the directions on MOHS, and I believe PRIME, say to use this as a finishing touch after coating. Thank you and I hope this helps!
